Bug 569 - Zooming in on bar chart does not widen the bars
Summary: Zooming in on bar chart does not widen the bars
Status: IN_PROGRESS
Reported: 2014-02-13 02:35 EST by h.hasenack
Modified: 2014-02-19 03:12 EST (History)
Chart Series: Bar
Unzoomed chart (57.86 KB, image/jpeg)
2014-02-13 02:35 EST, h.hasenack
Zoomed in without the proposed patch (59.55 KB, image/jpeg)
2014-02-13 02:37 EST, h.hasenack
Zoomed in with the patch applied (58.45 KB, image/jpeg)
Description h.hasenack 2014-02-13 02:35:19 EST
Created attachment 85 [details]
Unzoomed chart
When using a barchart, and Autobarwidth is FALSE, and zooming in eg using mouse the data is zoomed in but the bars do not get wider.
(Using the AutoBarsize=TRUE does not do what I require either)
CHeck the attachments for what I mean.
Heres the patch to be applied to TCusomBarSeries.CalcBarWidth
    if FAutoBarSize then
       tmp:=Round(IAxisSize/(2.0+Maximum-Minimum))
{$ifdef HH_PATCH_TC_ZOOMBARSIZE}
       lMax:=ParentChart.MaxXValue(NotMandatoryAxis);
       lMin:=ParentChart.MinXValue(NotMandatoryAxis);
       lZoomFactor:=Maximum-Minimum;
       if lZoomFactor>0.0 then
         lZoomFactor:=(lMax-lMin)/lZoomFactor
       else lZoomFactor:=1.0;
       tmp:=round(IAxisSize*lZoomFactor) div IMaxBarPoints;
{$else}
      // TV52014436
       tmp:=IAxisSize div IMaxBarPoints;
{$endif}
Comment 1 h.hasenack 2014-02-13 02:37:21 EST
Created attachment 86 [details]
Comment 2 h.hasenack 2014-02-13 02:37:58 EST
Created attachment 87 [details]
Comment 3 david berneda 2014-02-18 06:27:34 EST
Thanks for the patch.
Can you attach a example project?
The proposal looks fine for this specific case, but it will break other combinations of series, or multiple bar series that are "side-stacked", or with Horizontal Bar series, etc.
I'll try to improve this calculation when AutoBarSize=True.
Comment 4 h.hasenack 2014-02-19 03:12:47 EST
You can use the teechart office or teehcart demo app to reproduce.
Just pick a bar chart and zoom-in. Zoom works, but bars are not widened accordingly.
