Bug 566 - Adding data from a DataSet or DataTable not working.
Summary: Adding data from a DataSet or DataTable not working.
URL: http://stackoverflow.com/questions/21...
Reported: 2014-02-10 07:28 EST by narcís calvet
Modified: 2014-02-11 05:50 EST (History)
Description narcís calvet 2014-02-10 07:28:58 EST
Code below doesn't work in Xamarin.Android but works in a WinForms application.
    public DataSet DataSet_Obj = new DataSet();
    public DataRow DataRow_Obj;
    public Steema.TeeChart.TChart TChart1;
    public Steema.TeeChart.Styles.Candle Tag_Serie_Candle;
    protected override void OnCreate(Bundle bundle)
      base.OnCreate(bundle);
      RequestWindowFeature(WindowFeatures.NoTitle);
      TChart1 = new Steema.TeeChart.TChart(this.ApplicationContext);
      Steema.TeeChart.Themes.BlackIsBackTheme myTheme = new Steema.TeeChart.Themes.BlackIsBackTheme(TChart1.Chart);
      myTheme.Apply();
      LoadChart();
      SetContentView(TChart1);
    private void LoadChart()
      DataSet_Obj.Tables.Add("CandleTable");
      DataSet_Obj.Tables["CandleTable"].Columns.Add(new DataColumn("Date", System.Type.GetType("System.DateTime")));
      DataSet_Obj.Tables["CandleTable"].Columns.Add(new DataColumn("Open", System.Type.GetType("System.Double")));
      DataSet_Obj.Tables["CandleTable"].Columns.Add(new DataColumn("Close", System.Type.GetType("System.Double")));
      DataSet_Obj.Tables["CandleTable"].Columns.Add(new DataColumn("High", System.Type.GetType("System.Double")));
      DataSet_Obj.Tables["CandleTable"].Columns.Add(new DataColumn("Low", System.Type.GetType("System.Double")));
      for (int i = 0; i < 5; i++)
        DataRow_Obj = DataSet_Obj.Tables["CandleTable"].NewRow();
        DataRow_Obj["Date"] = DateTime.Now.AddDays(i);//Convert.ToDateTime("01/01/2005 10:00:00");
        DataRow_Obj["Low"] = 120;
        DataRow_Obj["Close"] = 130;
        DataRow_Obj["Open"] = 140;
        DataRow_Obj["High"] = 150;
        DataSet_Obj.Tables["CandleTable"].Rows.Add(DataRow_Obj);
        //DataRow_Obj = null;
      Tag_Serie_Candle = new Steema.TeeChart.Styles.Candle(TChart1.Chart);
      Tag_Serie_Candle.DataSource = DataSet_Obj.Tables["CandleTable"];
		Tag_Serie_Candle.OpenValues.DataMember = DataSet_Obj.Tables["CandleTable"].Columns["Open"].ToString();
		Tag_Serie_Candle.CloseValues.DataMember = DataSet_Obj.Tables["CandleTable"].Columns["Close"].ToString();
		Tag_Serie_Candle.DateValues.DataMember = DataSet_Obj.Tables["CandleTable"].Columns["Date"].ToString();
		Tag_Serie_Candle.DateValues.DateTime = true;
		Tag_Serie_Candle.HighValues.DataMember = DataSet_Obj.Tables["CandleTable"].Columns["High"].ToString();
		Tag_Serie_Candle.LowValues.DataMember = DataSet_Obj.Tables["CandleTable"].Columns["Low"].ToString();
		Tag_Serie_Candle.LabelMember = "Candle Chart";
		Tag_Serie_Candle.CheckDataSource();
