Bug 544 - Crash after export to metaFile, if CursorTool->Active set to false
Summary: Crash after export to metaFile, if CursorTool->Active set to false
: --- critical
Reported: 2014-01-21 09:23 EST by garethtyeparc
Modified: 2014-01-22 10:16 EST (History)
Simple C++builder project to reproduce error (12.96 KB, application/zip)
2014-01-21 09:23 EST, garethtyeparc
Description garethtyeparc 2014-01-21 09:23:52 EST
Created attachment 73 [details]
Access violation occurs after exporting chart as metafile with the TCusorTool
"Active" property set to false.
C++Builder XE4, TeeChartPro 131119
Windows 7 64bit
Steps to reproduce:
1) Create new VCL Project
2) Add TChart and add line series (Series1)
3) Add TCursorTool (ChartTool1)
4) Add OnFormCreate event to Form1 and add following to void TForm1::FormCreate()
     Series1->FillSampleValues(50);
     ChartTool->Active = false;
5) Add TButton to Form1 (Button1)
6) Add OnClick Event and add following to void TForm1::Button1Click()
     TeeExport( this, Chart1 );
7) In Export Chart dialog box select "as Metafile" in Format list box and then press "Preview..." button close preview and close dialog box
8) Click on Chart1 then get Access Violation.
Comment 1 sandra pazos 2014-01-22 09:50:03 EST
The problem only occurs if you have GDI+ mode activate. In Delphi occurs, too.
Delphi Code:
uses Series, TeExport;
  TeeExport(Self, Chart1);
Comment 2 david berneda 2014-01-22 10:16:41 EST
Fixed. After creating the Metafile (using a TMetafileCanvas), the problem was the "real" GDI+ chart canvas still had a wrong reference to the metafile canvas at its private "IXorCanvas" variable (used to draw the zoom rectangle when clicking and dragging a chart)
