Bug 530 - ErrorBar Series error is drawn incorrect when the error value is biggest than ErrorBar value and style is LeftRight
Summary: ErrorBar Series error is drawn incorrect when the error value is biggest than...
Reported: 2014-01-08 12:34 EST by sandra pazos
Modified: 2014-01-13 13:06 EST (History)
Description sandra pazos 2014-01-08 12:34:31 EST
If you have ErrorBar series and you set its error style to LeftRight, the error is drawn incorrectly, the problem only occurs when the error value is biggest than Bar value. Seems the problem is introduced when we fixed the bugs numbers TF02014259 and TV52015184.
The same problem occurs in TeeCharFor.Net version, bug number=529. The error is drawn correctly if you add Bar values biggest error value.
Next code reproduces the problem:
 type
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TErrorSeries;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
Series1.AddErrorBar(10, 0.3, 0.7);
Series1.ErrorStyle := essLeftRight;
Chart1.Axes.Bottom.SetMinMax(9.0,11.0);
Chart1.Axes.Left.SetMinMax(0,1);
Comment 1 david berneda 2014-01-13 10:05:41 EST
Is this Error series or ErrorBar series ?
ErrorBar does not allow changing the ErrorStyle property.
("essTop" is the default in ErrorBar series and the only supported style)
We can add support for the additional styles in future versions.
Comment 2 christopher ireland 2014-01-13 10:40:17 EST
Error series.
It is a defect and has been fixed in the .NET version:
http://bugs.teechart.net/show_bug.cgi?id=529
in id=529 there's an attachment with a form which tests a number of Error series variables. This defect is related to the use of CalcPosSize with logarithmic axes and the fix involves the addition of a new overload to this function.
If you look carefully at the example you will see that the Error line does not extend from 9.3 to 10.7 as it should, but from 9.7 to 10.3.
Comment 3 david berneda 2014-01-13 11:30:53 EST
Fixed. Error size for horizontal style (left, right, left right) was being calculated using the vertical position (YValue) instead of XValue.
