Bug 529 - ErrorBar Series error is drawn incorrect when the error value is biggest than ErrorBar value and style is LeftRight
Summary: ErrorBar Series error is drawn incorrect when the error value is biggest than...
: High normal
Reported: 2014-01-08 12:13 EST by sandra pazos
Modified: 2014-01-09 09:59 EST (History)
Latest revision (16.37 KB, image/png)
2014-01-08 12:13 EST, sandra pazos
Revision v1.13 (16.45 KB, image/png)
2014-01-08 12:16 EST, sandra pazos
Winform to test Error functionality (3.43 KB, application/x-zip-compressed)
2014-01-09 09:58 EST, christopher ireland
Description sandra pazos 2014-01-08 12:13:33 EST
Created attachment 65 [details]
Latest revision
If you have ErrorBar series and you set its error style to LeftRight, the error is drawn incorrectly when the error value is biggest than ErrorBar value. Seems the problem is introduced when we fixed the bugs numbers TF02014259 and TV52015184.
The same problem occurs in VCL version. The Error is drawn correctly in the revision v1.13 of the ErrorBar class and if you add ErrorBar values biggest error value.
Next code reproduces the problem:
 Error series1;
      series1 = new Steema.TeeChart.Styles.Error(tChart1.Chart);
      series1.ErrorStyle = ErrorStyles.LeftRight;
      series1.Add(10, 0.3, 0.7);
      series1.ErrorWidth = 10;
      tChart1.Axes.Bottom.SetMinMax(9.0, 11.0);
      tChart1.Axes.Left.SetMinMax(0, 1);
I have attached two images; one corresponds to latest revision of the ErrorBar class and the other to revision v1.13 of the ErrorBar class.
Comment 1 sandra pazos 2014-01-08 12:16:08 EST
Created attachment 66 [details]
Revision v1.13
Comment 2 christopher ireland 2014-01-09 09:58:29 EST
Created attachment 67 [details]
Comment 3 christopher ireland 2014-01-09 09:59:28 EST
Attachment "Winform to test Error functionality" demonstrates correct functioning of Error series with latest sources.
