Bug 528 - Too much margin between the axis labels and the ticks when multiline and LabelsAngle=90
Summary: Too much margin between the axis labels and the ticks when multiline and Labe...
: 1458 (view as bug list)
Reported: 2014-01-07 10:39 EST by yeray alonso
Modified: 2016-03-22 12:23 EDT (History)
4 users (show)
test application and screenshots (37.08 KB, application/octet-stream)
2014-01-07 10:39 EST, yeray alonso
Description yeray alonso 2014-01-07 10:39:22 EST
Created attachment 64 [details]
This happens from v2013.09. It didn't happen in v2013.08
Testing application attached with screenshots
Comment 1 david berneda 2014-01-08 07:35:54 EST
Note: Problem happens only when labels are multi-line (more than one line of text).
Comment 2 yeray alonso 2014-04-02 08:01:27 EDT
Another example here:
uses Series;
  with Chart1 do
    View3D:=False;
    with AddSEries(TLineSeries) as TLineSeries do
      XValues.DateTime:=True;
      FillSampleValues;
    BottomAxis.DateTimeFormat:='dd.MM hh:mm';
    BottomAxis.LabelsAngle:=90;
    BottomAxis.LabelsMultiLine:=True;
Done after seeing another customer:
http://www.teechart.net/support/viewtopic.php?p=65600#p65600
Comment 3 yeray alonso 2014-04-02 08:08:22 EDT
Not sure if related, but certainly adding this in the code from the last comment
  Axes.Bottom.Shape.Visible:=true;
Makes the labels not to be visible. But only in the circumstances above, because if you comment the DateTimeFormat then it works fine:
  //BottomAxis.DateTimeFormat:='dd.MM hh:mm';
Comment 4 yeray alonso 2015-11-06 11:03:04 EST
This other ticket also talks about rotated axis labels not being correctly calculated. And it's fixed:
http://bugs.teechart.net/show_bug.cgi?id=947
But the fix for that (#947) doesn't help for the ticket here (#528).
Comment 5 yeray alonso 2016-03-22 10:31:45 EDT
*** Bug 1458 has been marked as a duplicate of this bug. ***
Comment 6 marc meumann 2016-03-22 12:23:39 EDT
Resolved for inclusion in next update release.
