Bug 525 - Matching values on pie chart can swap colors on refresh
Summary: Matching values on pie chart can swap colors on refresh
Reported: 2013-12-20 12:39 EST by swensonk
Modified: 2013-12-23 10:40 EST (History)
Example of the original followed by the refresh (89.24 KB, image/jpeg)
2013-12-20 12:39 EST, swensonk
Description swensonk 2013-12-20 12:39:45 EST
Created attachment 63 [details]
We are using a chart with a gradient and marks.  But when we print these we disable the gradient and marks, and refresh the chart.  If you have two matching values, these can items can swap colors in the legend.
The following is the code we are using that is during the swap in colors.
procedure TfrmPieChart.tbPrintClick(Sender: TObject);
var OldOrient : TPrinterOrientation;
   PieChart.PrintMargins.Left := 3;
   PieChart.PrintMargins.Top := 3;
   PieChart.PrintMargins.Right := 3;
   PieChart.PrintMargins.Bottom := 3;
   PieChart.Gradient.Visible := False;
   PieChart.Border.Visible := False;
   PieChart.Shadow.Visible := False;
   PieChart.BevelOuter := bvNone;
  Series1.Marks.Visible := False;
  Series2.Marks.Visible := False;
  Series3.Marks.Visible := False;
  Series4.Marks.Visible := False;
   Printer.PrinterIndex := Printer.Printers.IndexOf(SysObject.ReportPrinter);
   if (Printer.PrinterIndex > -1) and (SysObject.ReportPrinterTray <> '') then begin
      SelectPrinterBin(PrinterBinGetIndex(SysObject.ReportPrinter, SysObject.ReportPrinterTray));
   OldOrient := Printer.Orientation;
   Printer.Orientation := poLandscape;
   if printdialog1.Execute then begin
      Printer.BeginDoc;
      try
         PieChart.Canvas := TTeeCanvas3D.Create;
         PieChart.PrintPartial(PieChart.ChartPrintRect);
      finally
         Printer.EndDoc
   Printer.Orientation := OldOrient;
   PieChart.Canvas:=TGDIPlusCanvas.Create;
   PieChart.Gradient.Visible := True;
  Series1.Marks.Visible := True;
  Series2.Marks.Visible := True;
  Series3.Marks.Visible := True;
  Series4.Marks.Visible := True;
   PieChart.Refresh; //Reset chart to original settings
Comment 1 david berneda 2013-12-23 10:09:25 EST
This problem is caused because there are duplicated Pie series values, and PieValues.Order :=  loAscending.
The internal sorting algorithm to order pie slices is a QuickSort, which is an "unstable" algorithm (it will swap duplicate values each run).
Code below reproduces the problem, clicking Button1:
  Series1.Repaint;
  Series1.Clear;
  Series1.Add(887,'a');
  Series1.Add(514,'b');
  Series1.Add(565,'c');
  Series1.Add(109,'d');
  Series1.Add(116,'e');
  Series1.Add(116,'f');
  Series1.Add(985,'g');
  Series1.Add(898,'h');
  Series1.PieValues.Order:=loAscending;
We'll try to modify QuickSort to make it "stable", to avoid reordering.
Comment 2 david berneda 2013-12-23 10:40:01 EST
Fixed. Changed source code below (TeEngine.pas unit, TChartSeries.CompareValueIndex method)
Function TChartValueList.CompareValueIndex(a,b:Integer):Integer;
var tmpA : TChartValue;
    tmpB : TChartValue;
  tmpA:=Value[a];
  tmpB:=Value[b];
  if tmpA<tmpB then result:=-1
  if tmpA>tmpB then result:=1
    // Use "a" and "b" indexes to avoid "unstable" results:
    if a<b then
       result:=-1  // -1 always, for both cases FOrder ascending or descending
       result:=0;
    Exit;
  if FOrder=loDescending then
     result:=-result;
