Bug 518 - Pie Series rotate leads to Invalid Pointer Operation when "Other" slice is activated
Summary: Pie Series rotate leads to Invalid Pointer Operation when "Other" slice is ac...
: High critical
Reported: 2013-12-17 06:52 EST by roth
Modified: 2013-12-17 08:10 EST (History)
Chart Series: Pie
Sample project to provoke Invalid Pointer Operation (56.90 KB, application/x-zip-compressed)
2013-12-17 06:52 EST, roth
Description roth 2013-12-17 06:52:50 EST
Created attachment 57 [details]
I See Invalid Pointer Operations when rotating my 3D pie Chart with activated "Other" slice.
Delphi XE5, TeeChart Pro V2013 (2013.09.131119)
Repro:
1. Open the attached sample Project in Delphi XE5 with installed TeeChart Pro V2013
2. Build and run the Project
3. Click inside the shown pie Chart and use the mouse wheel
-> Invalid Pointer Operation
Comment 1 david berneda 2013-12-17 08:10:23 EST
The problem was TChartSeries.Delete method was double-destroying a Marks.Positions and Marks.Items instance (XE4 and up only).
Correct code is:
      if FPositions.Count>ValueIndex then
        {$IFNDEF D18}
        FPositions[ValueIndex].Free;
        {$ENDIF}
        FPositions.Delete(ValueIndex);
      if FItems.Count>ValueIndex then
        {$IFNDEF D18}
        FItems[ValueIndex].Free;
        {$ENDIF}
        FItems.Delete(ValueIndex);
