Bug 495 - Buffer overrun in TSeriesBandTool.DrawBandTool
Summary: Buffer overrun in TSeriesBandTool.DrawBandTool
Reported: 2013-12-03 00:38 EST by Marc Durdin
Modified: 2013-12-04 08:20 EST (History)
Description Marc Durdin 2013-12-03 00:38:13 EST
The TSeriesBandTool.DrawBandTool function has a buffer overrun when it writes to the tmpPoints array.  Specifically, the length of the array is short by 2, 3, or 4 values.
The following code increments the length of the array, but then is not checked correctly when starting the iteration:
      // First point outside chart
      if Series.DrawBetweenPoints and (Series.FirstValueIndex>0) then
         Inc(l1);
         tmpMax:=Math.Max(0,Series.FirstValueIndex-1);
The fix should either be:
a) test for Series.DrawBetweenPoints when calculating tmpMax; or
b) don't test for Series.DrawBetweenPoints when calculating l1.
And the same fix must be applied for Series2.DrawBetweenPoints/l2.
I not not entirely clear on which is the appropriate solution, as I don't understand the reasoning behind the initial check for Series.DrawBetweenPoints.
Comment 1 david berneda 2013-12-04 08:20:37 EST
This problem should be fixed in latest sources.
Can you attach here a test project?
In the latest version, DrawBandTool had been changed quite a bit and there shouldn't be any overrun.
Also, the series DrawBetweenPoints property is no longer used.
(DrawBetweenPoints is True for series that need to paint in-between one point and the next point, like Line or Area series).
