Bug 494 - MouseDoubleClick event breaks the TeeChart PNG exportation in Windows XP
Summary: MouseDoubleClick event breaks the TeeChart PNG exportation in Windows XP
: Low normal
Reported: 2013-12-02 07:36 EST by sandra pazos
Modified: 2014-01-17 11:04 EST (History)
Description sandra pazos 2013-12-02 07:36:03 EST
When you work with WPF application and try to export the Chart to png image format, if you call export in the MouseDobleClick appears an exception.
This problem occurs if you use MouseDobleClick in Windows XP.
See next code to reproduce the problem:
        public MainWindow()
            InitializeChart();
            Steema.TeeChart.WPF.Styles.Line line1 = new Steema.TeeChart.WPF.Styles.Line(tChart1.Chart);
            line1.FillSampleValues();
            tChart1.MouseDoubleClick += new MouseButtonEventHandler(tChart1_MouseDoubleClick);
        void tChart1_MouseDoubleClick(object sender, MouseButtonEventArgs e)
           tChart1.Export.Image.PNG.Save("C:\\Test.png");
Comment 1 christopher ireland 2013-12-09 04:43:45 EST
Could not reproduce this using TeeChart.WPF.dll v.4.1.2013.11081 on WinXP SP3.
Comment 2 christopher ireland 2014-01-17 11:04:10 EST
This issue could be caused by a FocusVisualAdorner added in double-byte WinXP but not any other:
"Rather, it is the child of a
special adorner (FocusVisualAdorner) that is dynamically created by the
keyboard navigation manager."
http://brucezhou1986.wordpress.com/page/4/
check for this type seems to have resolved the problem.
