Bug 491 - AntiAlias tool is not working after loading a tee file
Summary: AntiAlias tool is not working after loading a tee file
Blocks: 540
  Show dependency treegraph
Reported: 2013-11-29 03:32 EST by Bert Kreisel
Modified: 2014-01-20 09:02 EST (History)
Delphi / C++ Builder RAD IDE Version: RAD XE3
Description Bert Kreisel 2013-11-29 03:32:25 EST
TeeChartOffice -> Chart -> Change Series type to LineSerie -> add AntiAlias tool -> see the difference switching AntiAlias off/on -> Leave it On -> Save tee File
Click New Chart to Clear the Chart -> Load the saved Tee file -> see that AntiAlias is not working
Comment 1 david berneda 2013-11-29 12:54:44 EST
Note:
AntiAlias tool will soon be deprecated (obsolete).
It will be changed to use a GDI+ canvas internally, as GDI+ canvas does anti-aliasing of diagonals and curves in a much better (and faster) way.
For FireMonkey this tool was already not available so its not a problem.
Regarding FireMonkey, anti-aliasing is a global setting at TForm level, not at control or canvas level.   (The Form1.Quality property).
btw:
Currently FireMonkey antialias is disabled by default in iOS platform.
The TAntiAlias tool will still be available and compatible.
Setting AntiAlias to Yes/No will simply set the GDI+ canvas AntiAlias property True/False.
About the bug, I'll make sure it works fine with the new changes.
Comment 2 david berneda 2013-12-04 09:26:54 EST
AntiAlias property now correctly used when loading a *.tee Chart file or at design-time.
When a TAntiAliasCanvas is used, it shows at Chart editor dialog -> 3D -> Render tab.
When its not used, as it is now deprecated (obsolete), it does not appear as an option at "Render" tab.
(Choose GDI+, as its exactly the same now as TAntiAliasCanvas)
