Bug 482 - Color mapping font of for treenodes
Summary: Color mapping font of for treenodes
Component: TTree (show other bugs)
Reported: 2013-11-27 04:40 EST by h.hasenack
Modified: 2013-12-04 09:47 EST (History)
Description h.hasenack 2013-11-27 04:40:49 EST
As for my previous reported patch on TeeTree panel, there is another issue for drawing the text of TTreeNodeshape. The system color values (like clWindowText) are not mapped into rgb values, and as these system values are negative, they are drawn as transparent values, thus become invisible.
Here's the fix I come up with:
Procedure TTreeNodeShape.SetCanvasFont(const ACanvas:TCanvas3D);
  if not Assigned(Tree) then
     ACanvas.AssignFont(InternalFont)
  with Tree do
  if Self.FSelected and
     (Selected.TextColor<>clNone) and
     (not Designing) then
    ACanvas.AssignFont(InternalFont);
    ACanvas.Font.Color:=Selected.TextColor;
  end
    // HotTrack ...
    if IMouseInside and (not Designing) and
       HotTrack.Active then
      if HotTrack.UseFont then
         ACanvas.AssignFont(HotTrack.Font)
      if HotTrack.HotLink then
        with ACanvas.Font do Style:=Style+[{$IFDEF FMX}TFontStyle.{$ENDIF}fsUnderline];
    end
{$ifdef HH_PATCH_TEETREE}
  aCanvas.Font.Color:=ColorToRGB(aCanvas.Font.Color);
{$endif}
Comment 1 david berneda 2013-12-04 09:47:31 EST
Fixed with the code below.
But, there is a (minor) problem with "system" colors like "clWindowText" etc.
When using GDI+ canvas (the default canvas now), colors are expressed using the 4 bytes of a Cardinal (RGBA format) instead of just 3 bytes (RGB).
That means, GDI+ does not interpret and does not know if a color is a "system" color by looking at the 4 byte. This is only a VCL mechanism intended only for "old" GDI. The 4 byte (A) is used to determine the transparency from 0 to 255.
In GDI+, a "clWindowText" color ($FF000008) is a perfect valid color, (a totally transparent RGB with Red=8), and so, when calling ColorToRGB it will be converted (in VCL only).  FireMonkey follows GDI+ specs (4 bytes RGBA and no special system colors).
{$IFNDEF FMX}
{$IFNDEF LCL}
{$IFNDEF CLX}
var tmpColor : TColor;
{$ENDIF}
{$ENDIF}
{$ENDIF}
    {$IFNDEF FMX}
    {$IFNDEF LCL}
    {$IFNDEF CLX}
    tmpColor:=ACanvas.Font.Color;
    if (Cardinal(tmpColor)>={$IFDEF D7}clSystemColor{$ELSE}$80000000{$ENDIF}) and
       (Cardinal({$IFDEF D6}clMenuBar{$ELSE}clInfoBk{$ENDIF})>=Cardinal(tmpColor)) then
       ACanvas.Font.Color:=ColorToRGB(tmpColor);
    {$ENDIF}
    {$ENDIF}
    {$ENDIF}
