Bug 473 - TCustomTeePanel.PanelCOlor returns wrong colors when using teetree
Summary: TCustomTeePanel.PanelCOlor returns wrong colors when using teetree
Reported: 2013-11-26 04:19 EST by h.hasenack
Modified: 2013-11-26 06:16 EST (History)
Description h.hasenack 2013-11-26 04:19:12 EST
In my teetree I want to use clWindow as background color, unfortunately due to anything other than clBtnFace is not translated into an RGB color, causing transparent colors to fill the rect (system colors are negative values causing the transparency). This off course does not clear the rect causes the tree not to be cleared when collapsing or expanding nodes.
The solution is pretty simple, instead of the "Result=clBtnFace" test I use the ColorToIdent routine to check if the color is some native color identifier. It it is, the COlorToRGB routine is used as before.
The adjusted code in TeeProcs.pas code now looks like this:
function TCustomTeePanel.PanelColor:TColor;
{$ifdef HH_PATCH_TEETREE} // this patch allows more than only clBtnFace to be used as system color
VAR sDummy:string;
{$endif}
  {$IFDEF FMX}
  result:=Color;
  {$ELSE}
  if ParentColor and Assigned(Parent) then
     result:={$IFNDEF CLR}TControlAccess{$ENDIF}(Parent).Color
     result:=Color;
  {$IFDEF LCL}
  if result=clDefault then
     result:=$F0F0F0; //??
  {$ELSE}
  if ColorToIdent(Result,sDummy) then
    result:=ColorToRGB(result)
{$else}
  if result=clBtnFace then
{$endif}
  {$ENDIF}
  {$ENDIF}
Comment 1 h.hasenack 2013-11-26 04:21:01 EST
Teetree lacks using colors from the style manager. Unsure wheter this is a choice or something forgotten.
Comment 2 david berneda 2013-11-26 06:10:09 EST
(In reply to h.hasenack from comment #1)
I guess its forgotten, we'd like very much to support both VCL and FMX Style / Theme colors and settings, but never had decided how to do it.
If possible, can you attach a test project using themes / styles that can reproduce the problem?  The big decision I think is which style items should be considered for which elements of TTree (and TChart).
Comment 3 david berneda 2013-11-26 06:16:14 EST
(In reply to h.hasenack from comment #0)
> VAR sDummy:string;
> {$endif}
> begin
>   {$IFDEF FMX}
>   result:=Color;
>   {$ELSE}
>   else
>      result:=Color;
>   {$IFDEF LCL}
>   {$ELSE}
> {$else}
> {$endif}
>   {$ENDIF}
>   {$ENDIF}
> end;
This problem has already been fixed. It should be included in next update, and  earlier at our soon-to-be-released "nightly" builds.
More info here:
http://www.teechart.net/support/viewtopic.php?f=3&t=14509&p=63969
I choose a different approach than using ColorToIdent (see below). Its more "hardcoded" but it runs faster.
  // This fix is for GDI+ only, that cannot accept the "fake" VCL 4 byte colors
  // defined in Graphics.pas (the System colors like clWindow, clHighLight, etc)
  if result=clNone then
     result:=clBlack
  if (Cardinal(result)>={$IFDEF D7}clSystemColor{$ELSE}$80000000{$ENDIF}) and
     (Cardinal({$IFDEF D6}clMenuBar{$ELSE}clInfoBk{$ENDIF})>=Cardinal(result)) then
