Bug 448 - ColorLine draw out of bound Chart when AllowDrag is false
Summary: ColorLine draw out of bound Chart when AllowDrag is false
Reported: 2013-11-21 04:01 EST by sandra pazos
Modified: 2013-11-22 05:37 EST (History)
Description sandra pazos 2013-11-21 04:01:43 EST
When you there is a ColorLine tool in a Chart with AllowDrag property to false, if you scroll the Chart the ColorLine is drawn out of bounds of Chart.
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TFastLineSeries;
    ChartTool1: TColorLineTool;
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form1: TForm1;
implementation
{$R *.dfm}
Series1.FillSampleValues(100);
ChartTool1.Axis := Chart1.Axes.Left;
ChartTool1.Value := Series1.YValue[3];
ChartTool1.AllowDrag := False;
ChartTool1.NoLimitDrag := False;
The same problem occurs in TeeChartFor.Net.
Comment 1 sandra pazos 2013-11-21 04:02:12 EST
The TeeChartFor.Net bug number is [id447]
Comment 2 david berneda 2013-11-22 05:37:25 EST
When AllowDrag is True, scrolling outside the chart will force the color line position to be inside, so it will be always visible.
When AllowDrag is False, the color line will not be painted if its outside the axis Min to Max range.
