Bug 441 - [TJ71015760] Running: tChart1.getExport().getTemplate().toXML("C:\\temp\\testJava...
Summary: [TJ71015760] Running: tChart1.getExport().getTemplate().toXML("C:\\temp\\test...
Reported: 2011-09-28 17:08 EDT by christopher ireland
Modified: 2016-03-11 09:51 EST (History)
Description christopher ireland 2013-11-20 12:16:49 EST
Running:
tChart1.getExport().getTemplate().toXML("C:\\temp\\testJava.xml");
works ok, but trying to import this again using:
tChart1.setChart(tChart1.getImport().getTemplate().fromXML("C:\\temp\\testJava.xml"));
does not work. [created:2011-09-28T16:08:44.000+01:00 reported by:chris@steema.com reported in version:]
Comment 1 yeray alonso 2016-03-11 09:44:14 EST
Problem reproduced with v3.0.0.030 both in SWT and Swing.
Since commit below, you can import the generated .xml in both SWT and Swing:
http://steema.cat:802/TeeChart_Java/Sources/commit/41071a306d14bc344c4aed7598baf6d8727812bb
When you export the chart to the xml in Swing some errors still appear, but that's a different issue, reported in the bug 434
Comment 2 yeray alonso 2016-03-11 09:51:10 EST
(In reply to yeray alonso from comment #1)
Sorry, the errors still appearing are in SWT, not in Swing.
I've created a new ticket reporting these errors: bug 1466
