Bug 44 - Sources path for Firemonkey XE2 and XE3 should be different than XE4 and up
Summary: Sources path for Firemonkey XE2 and XE3 should be different than XE4 and up
Product: FireMonkey TeeChart
Version: 131016
Reported: 2013-10-21 06:01 EDT by david berneda
Modified: 2013-10-21 06:04 EDT (History)
Delphi / C++ Builder RAD IDE Version: RAD XE2
Description david berneda 2013-10-21 06:01:50 EDT
When using the TeeRecompile.exe tool, TeeChart for FireMonkey sources get copied and converted at:  "...\Sources\FMX"  subfolder.
This conversion depends on the RAD XE version, due to incompatible *.fmx forms between XE2/3 and XE4 and up.
For XE4 and up, *.fmx forms are copied from "Sources\FMX_XE35" folder instead of just "Sources" folder.
This is problematic if you want to compile your projects against the "FMX" sources folder, recompiled using a different XE version than the one you're using.
A solution would be TeeRecompile.exe to generate different "FMX" folders. One folder for XE2/3 and another folder for XE4 and up.
For example:
...\Sources\FMX3   <--- XE2 and XE3
...\Sources\FMX    <--- XE4 and up
This request is to make TeeRecompile.exe to generate different FMX source folders depending on RAD XE version.
