Bug 425 - [TJ71016459] Having a Bar series, if you set the gradient StartColor and EndColor,...
Summary: [TJ71016459] Having a Bar series, if you set the gradient StartColor and EndC...
Reported: 2012-12-19 11:10 EST by yeray alonso
Modified: 2013-12-13 10:26 EST (History)
Description yeray alonso 2013-11-20 12:15:56 EST
Having a Bar series, if you set the gradient StartColor and EndColor, the StartColor is correctly used, but the series' Color is used instead of the EndColor.
Reproduced in SWT and Android
		Bar bar = new Bar(tChart1.getChart());
		bar.fillSampleValues();
		//bar.setColorEach(true);
		bar.setBarStyle(BarStyle.RECTGRADIENT);
		bar.getBrush().getGradient().setDirection(GradientDirection.VERTICAL);
		bar.getBrush().getGradient().setUseMiddle(false);
		bar.getBrush().getGradient().setStartColor(Color.white);
		bar.getBrush().getGradient().setEndColor(Color.red);
		// WORKAROUND: Setting the color yields a valid gradient.
		//bar.setColor(Color.purple);/**/
http://stackoverflow.com/questions/13927331/bar-setbarstylebarstyle-rectgradient-does-not-work-as-intended [created:2012-12-19T11:10:26.000+01:00 reported by:yeray@steema.com reported in version:3.2012.0808 (TeeChart Java)]
Comment 1 marc meumann 2013-12-13 10:26:54 EST
Now uses Clone Gradient as workspace for calculated canvas rendering colours. Active in Dec 2013 build.
