Bug 420 - [TJ71016541] In TeeChart Java Android, when you add a SeriesBand some parts of the...
Summary: [TJ71016541] In TeeChart Java Android, when you add a SeriesBand some parts o...
Reported: 2013-03-20 13:46 EDT by yeray alonso
Modified: 2017-06-13 05:30 EDT (History)
Description yeray alonso 2013-11-20 12:15:34 EST
In TeeChart Java Android, when you add a SeriesBand some parts of the chart seem to be drawn relative to wrong parts of the view. See the title and the area in the following cases.
Case 1:
Having the chart in the root layout, if we have some more objects, the title and the area series are drawn as if the chart took all the space.
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent"
    android:id="@+id/chart_layout1" >
    <Spinner
        android:layout_width="match_parent"
        android:layout_height="wrap_content" />
    <Spinner
</LinearLayout>
Here's the code:
  Area area1 = new Area(tChart1.getChart());
  area1.fillSampleValues();
  SeriesBand band1 = new SeriesBand(tChart1.getChart());
  band1.setSeries(area1);
  tChart1.getPanel().setMarginUnits(PanelMarginUnits.PIXELS);
  tChart1.getPanel().setMarginTop(30);
  tChart1.getHeader().setCustomPosition(true);
  tChart1.getHeader().setTop(7);
  DisplayMetrics metrics = new DisplayMetrics();
  getWindowManager().getDefaultDisplay().getMetrics(metrics);
  int headerWidth = tChart1.getGraphics3D().textWidth(tChart1.getHeader().getText());
  tChart1.getHeader().setLeft(metrics.widthPixels/2 - headerWidth/2);
See the image "Case 1".
Case 2:
Having the chart in an second layout, the above problem is fixed.
However, if you add some padding to the chart layout, the same elements are moved again. And they seem to be moved as many pixels as the padding indicates.
    android:layout_height="fill_parent">
    <Spinner
    <Spinner
	<LinearLayout android:id="@+id/chart_layout1"
	    android:padding="10dip" />
</LinearLayout>
See the image "Case 2". [created:2013-03-20T13:46:58.000+01:00 reported by:yeray@steema.com reported in version:3.2012.0808 (TeeChart Java)]
