Bug 408 - [TF77016274] Fast Cursor for the Cursor tool. At the moment, the whole chart is r...
Summary: [TF77016274] Fast Cursor for the Cursor tool. At the moment, the whole chart ...
Reported: 2012-07-26 11:06 EDT by yeray alonso
Modified: 2013-11-25 15:47 EST (History)
Description yeray alonso 2013-11-20 11:59:32 EST
At the moment, the whole chart is repainted each time the cursor tool is moved.
Theoricaly, html5 canvas suports xor:
https://developer.mozilla.org/samples/canvas-tutorial/6_1_canvas_composite.html
Tip: To make it work, it may be needed to call getContext each time the cursor is redrawn.
Customer interested: aldreen.sansone@iastech.com [created:2012-07-26T10:06:32.000+01:00 reported by:yeray@steema.com reported in version:]
Comment 1 david berneda 2013-11-25 10:17:13 EST
The problem with html5 blending (xor, etc) is that it only works in between getContext calls.
ie: As soon you finish drawing, and then moving the mouse, calling getContext again will enable xor blending but only for the items you draw with that context.
The previously painted chart contents are not used to do the blending.
Comment 2 christopher ireland 2013-11-25 10:30:30 EST
(In reply to david berneda from comment #1)
> getContext calls.
> with that context.
If XOR cannot solve the problem of the whole chart being repainted on every mouse move, how about caching everything but the cursor tool as an image? That way redrawing will only have to paint the image and the cursor tool ...
Comment 3 david berneda 2013-11-25 15:37:13 EST
(In reply to chris ireland from comment #2)
> > getContext calls.
> > with that context.
Yes this is already supported with cursor's "render" property:
http://www.steema.com/files/public/teechart/html5/v2012.12.14.1.4/demos/extra/CursorTool.htm
"Keep a copy" does caching, and "Layer on top" uses a layer (another canvas) on top, with transparent background (similar to xor support in vcl gdi+)
Speed depends on browser, chart size etc. Layer style likely shows some lag/tearing.
Comment 4 christopher ireland 2013-11-25 15:47:46 EST
> lag/tearing.
Excellent, then this may just be the answer to the client's original question of how to avoid painting the entire chart on every cursor movement.
