Bug 396 - [TA05014281] Adding a chart into a second tab in a usercontrol, in a dll applicati...
Summary: [TA05014281] Adding a chart into a second tab in a usercontrol, in a dll appl...
Reported: 2009-07-08 14:22 EDT by yeray alonso
Modified: 2013-11-20 11:43 EST (History)
Description yeray alonso 2013-11-20 11:43:46 EST
Adding a chart into a second tab in a usercontrol, in a dll application, the chart is not shown.
See the customer example attached.
The customer who asked for it via mail:
paolo.becchi@cetena.it
And here is his message:
" I'm working with Visual Basic 2008 and your tools, but I have some problems concerning the coupling of a Microsoft TabPage Control and AxTChart control. I would like to set a TabPage Control with a AxTChart graph on each page on a dll project, but when I start debug I can see only the TChart control related to the first tab page, it is not related to the single control because it occurs again also if I switch the two pages. Then, I tried to do the same thing on a WindowsApplication project, putting the TabPage Control on a form, and it works properly... can you tell me why? I think it is a AxTChart problem, how can it be solved? In attachment I included a zip file with two examples, running it you should see that in the Form project there is no problems, while in the Ocx project you will be able to see only the TChart control of the first page." [created:2009-07-08T13:22:48.000+01:00 reported by:yeray@steema.com reported in version:Version AX8 Release 8006 (TeeChart ActiveX Control)]
