Bug 381 - [TF02013505] I would like to add a tooltip to the bottom axis labels so that if th...
Summary: [TF02013505] I would like to add a tooltip to the bottom axis labels so that ...
Reported: 2008-10-30 12:09 EDT by narcís calvet
Modified: 2013-12-02 11:39 EST (History)
Description narcís calvet 2013-11-20 11:26:39 EST
I would like to add a tooltip to the bottom axis labels so that if the mouse is above a label I will present some data. The labels are vertical.
[img]http://picasaweb.google.com/ryan.hardoon/TChartIssues#5262481354581063314[/img]
I did a test with a graph with 25 labels on the x axis , using the Chart.Axes.Bottom.Labels.Clicked to check which label the mouse is on.
I found several problems
1. it returns a valid index only when the mouse is on part of the label . on other parts of the label it returns -1.
It calculates Clicked method as if Labels.Angle was set to zero, code to reproduce:
 InitializeChart();
 Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
 Random y = new Random();
 for (int i = 0; i < 10; i++)
 bar1.Add(y.Next(),"Quite a long axis label #" + (i+1).ToString());
 tChart1.GetAxisLabel += new Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel);
 tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
 tChart1.Draw();
 void tChart1_MouseMove(object sender, MouseEventArgs e)
 int index = tChart1.Axes.Bottom.Labels.Clicked(e.X, e.Y);
 this.Text = index.ToString();
 void tChart1_GetAxisLabel(object sender, Steema.TeeChart.GetAxisLabelEventArgs e)
 if (((Steema.TeeChart.Axis)sender).Equals(tChart1.Axes.Bottom))
 if (e.LabelText.Length > 15)
 e.LabelText = string.Format("{0}{1}", e.LabelText.Substring(0, 15), "...");
 } [created:2008-10-30T12:09:58.000+01:00 reported by:narcis@steema.com reported in version:Build 3.5.3146.24804 (TeeChart for .NET)]
Comment 1 christopher ireland 2013-12-02 11:39:42 EST
Axis labels now correctly respond to clicks when Angle>0.
