Bug 380 - [TF02013544] WebChart1.Chart.Axes.Bottom.Labels.Angle = 45; only maximum 7 labels ...
Summary: [TF02013544] WebChart1.Chart.Axes.Bottom.Labels.Angle = 45; only maximum 7 la...
Component: WebChart (show other bugs)
Reported: 2008-11-06 12:39 EST by narcís calvet
Modified: 2016-03-01 15:52 EST (History)
Description narcís calvet 2013-11-20 11:26:36 EST
WebChart1.Chart.Axes.Bottom.Labels.Angle = 45; only maximum 7 labels display but if I put WebChart1.Chart.Axes.Bottom.Labels.Angle = 90; it displays all (more than 20also). But doesn't work completelly fine with 90 degrees as can be seen in TChartV3Tester.zip project attached. Setting Angle=90 admits little bit larger labels than setting it to 0
what should be done to display all using WebChart1.Chart.Axes.Bottom.Labels.Angle = 45; and also when I define this property graph size reduces to half.
Code to reproduce:
 InitializeChart();
 Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
 bar1.Marks.Visible = false;
 Random y = new Random();
 for (int i = 0; i < 50; i++)
 bar1.Add(y.Next(), "bar number " + (i + 1).ToString());
 tChart1.Axes.Bottom.Labels.Angle = 45;
 } [created:2008-11-06T12:39:02.000+01:00 reported by:narcis@steema.com reported in version:Build 3.5.3225.32183 (TeeChart for .NET)]
