Bug 362 - [TW16015460] Seems there are a problem when you want use button right to do zoom. ...
Summary: [TW16015460] Seems there are a problem when you want use button right to do z...
Status: IN_PROGRESS
Reported: 2011-03-24 12:55 EDT by sandra pazos
Modified: 2016-09-30 07:05 EDT (History)
Description sandra pazos 2013-11-20 11:25:39 EST
Seems there are a problem when you want use button right to do zoom. Basically the problem is if you press down the mouse right button and try zoomed the chart, selected rectangle don't disappears and chart isn't able to do  zoom.
Next code allow you reproduce the problem:
            Steema.TeeChart.WPF.Styles.Bar bar1 = new Steema.TeeChart.WPF.Styles.Bar(tChart1.Chart);
            bar1.FillSampleValues();
            tChart1.Zoom.MouseButton = MouseButton.Right;
The same code works fine in WinForm version.
It is possible that it have related with when you do double click with button have to active  zoom , so occurs the same as you switch button right and left functionalities. [created:2011-03-24T12:55:14.000+01:00 reported by:sandra@steema.com reported in version:]
