Bug 357 - [TM71016212] The legend is created and looks pretty good. However, the last item i...
Summary: [TM71016212] The legend is created and looks pretty good. However, the last i...
Component: iOS (show other bugs)
Reported: 2012-06-06 13:13 EDT by sandra pazos
Modified: 2013-11-20 11:25 EST (History)
Description sandra pazos 2013-11-20 11:25:23 EST
The legend is created and looks pretty good. However, the last item in the list always seems to run over the end of the legend box. I have checked if the same problem occurs when use WinForms and the behavior is different and the problem doesn't appear, basically when the item doesn't fit in the rectangle of legend, the legend is resized. I think that the legend in MonoTouch must have same behavior as in WinForms.
I have made attached a simple code I used to reproduce the behavior in Winforms.
            InitializeChart();
            for (int i = 0; i < 4; i  )
                new Steema.TeeChart.Styles.Line(tChart1.Chart);
                tChart1[i].FillSampleValues();
            tChart1[0].Title = "Operating";
            tChart1[1].Title = "Occupied";
            tChart1[2].Title = "Pct Occupied";
            tChart1[3].Title = "Target Pct Occupied";
            //Setup the chart legend on the bottom of the graph.
            tChart1.Legend.Visible = true;
            tChart1.Legend.LegendStyle = LegendStyles.Series;
            tChart1.Legend.Alignment = LegendAlignments.Bottom;
            tChart1.Legend.AutoSize = true;
            tChart1.Legend.Symbol.WidthUnits = LegendSymbolSize.Pixels;
            tChart1.Legend.HorizMargin = 15;
            tChart1.Legend.Width = 600;
            tChart1.MouseClick  = new MouseEventHandler(tChart1_MouseClick);
            //Sandra adding
            //tChart1.Legend.Symbol.Width = 15;
            //tChart1.Legend.MaxNumRows = 1;
        } [created:2012-06-06T12:13:52.000+01:00 reported by:sandra@steema.com reported in version:]
