Bug 350 - [TD29016645] There is a strange problem when you do Ctrl+Alt+Supr with Direct2D de...
Summary: [TD29016645] There is a strange problem when you do Ctrl+Alt+Supr with Direct...
Status: IN_PROGRESS
Component: Direct2D (show other bugs)
Reported: 2013-07-17 13:09 EDT by sandra pazos
Modified: 2019-01-25 03:28 EST (History)
Screenshot of the Direct2D error (177.04 KB, image/png)
2013-11-27 10:24 EST, christopher ireland
Description sandra pazos 2013-11-20 11:25:02 EST
There is a strange problem when you do Ctrl+Alt+Supr with Direct2D demo project. To reproduce the problem with demo, you need follow next steps:
1.- Open Demo Direct2D
2.- Do Ctrl+Alt+Supr
3.- Return to the session.
A similar problem occurs if you run the attach project and open Task Manager, doing ctrl+Alt+Supr, when the project is running. The problem causes and exception in the method ShowImage
public override void ShowImage(Graphics g)
      if (!gd.IsOccluded)
        gd.EndDraw();
      //DisposeObj();
      base.ShowImage(g);
And also I have attached an image where you see the error there appears in the project in the design time.
Thread: http://www.teechart.net/support/viewtopic.php?f=4&t=14198 [created:2013-07-17T12:09:00.000+01:00 reported by:sandra@steema.com reported in version:]
Comment 1 christopher ireland 2013-11-27 10:24:17 EST
Created attachment 37 [details]
Comment 2 sandra pazos 2013-11-27 10:26:58 EST
(In reply to chris ireland from comment #0)
Have been able to reproduce this error here using the SlimDX source code. The error is shown in the attached screenshot.
The error seems to be coming from Direct2D itself and not from either the SlimDX or the TeeChart API. I have been unable to find a resolution to this problem for the moment.
Comment 3 henrik.surm+bugzilla 2019-01-25 03:28:33 EST
I found a workaround for this problem. Subclass TChart, catch the exception in OnPaint an recreate the Graphics3D object:
using System.Windows.Forms;
using SlimDX.Direct2D;
using Steema.TeeChart;
using Steema.TeeChart.Drawing.Direct2D;
public class TChartEx : TChart
    protected override void OnPaint(PaintEventArgs pe)
        try
            base.OnPaint(pe);
        catch (Direct2DException e)
            if (e.ResultCode == ResultCode.RecreateTarget)
                var oldGraphics = Graphics3D;
                Graphics3D = new Graphics3DDirect2D(Chart);
                // Copy properties of old Graphics object
                Graphics3D.BufferStyle = oldGraphics.BufferStyle;
                Graphics3D.BackColor = oldGraphics.BackColor;
                Graphics3D.Brush = oldGraphics.Brush;
                Graphics3D.Font = oldGraphics.Font;
                Graphics3D.FourPoints = oldGraphics.FourPoints;
                Graphics3D.Gradient = oldGraphics.Gradient;
                Graphics3D.NameElements = oldGraphics.NameElements;
                Graphics3D.Pen = oldGraphics.Pen;
                Graphics3D.RotationCenter = oldGraphics.RotationCenter;
                Graphics3D.RotationCenterFloat = oldGraphics.RotationCenterFloat;
                Graphics3D.SmoothingMode = oldGraphics.SmoothingMode;
                Graphics3D.Supports3DText = oldGraphics.Supports3DText;
                Graphics3D.SupportsID = oldGraphics.SupportsID;
                Graphics3D.Tag = oldGraphics.Tag;
                // Add more properties if needed
                oldGraphics.Dispose();
                throw;
