Bug 346 - [TW16016674] If you export Chart to pdf, the exportation doesn't work if you add ...
Summary: [TW16016674] If you export Chart to pdf, the exportation doesn't work if you...
Reported: 2013-08-02 11:38 EDT by sandra pazos
Modified: 2013-11-20 11:24 EST (History)
Description sandra pazos 2013-11-20 11:24:50 EST
If you export Chart to pdf, the exportation doesn't work  if you add  double values for width and height of ChartRect, panel  or Series. Considering pdf doesn't support double values, to draw use int values, and in WPF the width and height are double we should consider this point internally in the moment of export the Chart to pdf, for example, doing a  Math.Round or Math.Truncate to prevent  the  incorrect exportation.
Using next code you can reproduce the problem:
          FastLine fastLine1 = new FastLine(tChart1.Chart);
          tChart1.Header.Font.Bold = true;
          tChart1.Header.Font.Size = 15;
          fastLine1.FillSampleValues();
          fastLine1.LinePen.Width = 0.5;
          button1.Click += button1_Click;
        void button1_Click(object sender, RoutedEventArgs e)
          tChart1.Export.Image.PDF.Width = 400.3;
          tChart1.Export.Image.PDF.Height = 300.3;
          tChart1.Export.Image.PDF.Save(@"C:\testChart.pdf");
        } [created:2013-08-02T10:38:32.000+01:00 reported by:sandra@steema.com reported in version:]
