Bug 342 - [TF02016728] The Importation a Xmldocument isn't working correctly. The problem is...
Summary: [TF02016728] The Importation a Xmldocument isn't working correctly. The probl...
Reported: 2013-09-24 13:39 EDT by sandra pazos
Modified: 2024-03-05 03:40 EST (History)
Description sandra pazos 2013-11-20 11:24:37 EST
The Importation a Xmldocument isn't working correctly. The problem is produced in the AllFeatures\Welcome! \Component\XMLSource, it throw an exception when you click the Draw from Internet button appears an ArgumentException: "URI format isn't supported."
I have been debugging the source code, and comparing it with other versions of TeeChartFor.Net I realized that in version 3 of TeeChartFor.Net it works fine and the only difference is in the class XLIimport.cs, concretely, in load method. Basically in version 3, this doesn't use the StreamReader method to import or not the xmlDocument. I know that the streamReader(fileName,true) is used to solve the Bug number TF02015777, but the solution breaks the XmlDocument load.
Code of method load of XLIImport.cs class in version 4:
  public void Load(string fileName)
      using (StreamReader sr = new StreamReader(fileName, true)) //CDI TF02015777
        XmlDocument d = new XmlDocument();
        d.Load(fileName);
        Load(d);
Code of method load of XLIImport.cs class in version 3:
        d.Load(fileName);
        Load(d);
} [created:2013-09-24T12:39:00.000+01:00 reported by:sandra@steema.com reported in version:]
Comment 1 Edu 2024-03-05 03:40:51 EST
Solved with pre-release build, March 2024.
1.- Changed how the Load(string fileName) works
2.- Changes in Load(XmlDocument d) --> XPathNodeIterator select wasn't working
(xpath expressions are case-sensitive and there was a mistake because of that)
