Bug 340 - [TW16016733] When you add ColorBand to TChart, then remove it, the color lines ar...
Summary: [TW16016733] When you add ColorBand to TChart, then remove it, the color lin...
Reported: 2013-10-08 15:06 EDT by sandra pazos
Modified: 2019-12-12 03:47 EST (History)
Description sandra pazos 2013-11-20 11:24:32 EST
When you add  ColorBand to TChart, then remove it, the color lines aren't disappear. It problem only occurs in WPF version, so the same code works in correct way in Winforms. Could you see next code to check the problem:
        public MainWindow()
            MyTChart.Aspect.View3D = false;
            MyTChart.Width = 400;
            MyTChart.Height = 300;
            MyTChart.Axes.Left.SetMinMax(0, 10);
            colorBand = new ColorBand();
            MyTChart.Tools.Add(colorBand);
            colorBand.Axis = MyTChart.Axes.Left;
            colorBand.Color = Colors.Green;
            colorBand.End = 7;
            colorBand.ResizeEnd = true;
            colorBand.ResizeStart = true;
            colorBand.Start = 3;
        ColorBand colorBand;
        private void Button_Click(object sender, RoutedEventArgs e)
          MyTChart.Tools.Remove(colorBand);
        } [created:2013-10-08T14:06:16.000+01:00 reported by:sandra@steema.com reported in version:]
