Bug 317 - [TV52015580] For some reason, TeeCreateBitmap and Refresh can't be called together...
Summary: [TV52015580] For some reason, TeeCreateBitmap and Refresh can't be called tog...
Reported: 2011-05-19 14:26 EDT by yeray alonso
Modified: 2013-12-04 05:18 EST (History)
Description yeray alonso 2013-11-20 10:38:08 EST
Deppending on the machine, the following code ends soon or late with an EOutOfResources exception.
uses Chart;
var tc: TChart;
  tc:=TChart.Create(Self);
  tc.Parent:=Form1;
var tbm: TBitmap;
    i: Integer;
  i:=0;
  while True do
    Inc(i);
    Caption:=IntToStr(i);
    tbm:=tc.TeeCreateBitmap(tc.BackColor,Rect(0,0,1024,1024));
    tbm.Free;
    tc.Refresh;
In TeeProcs.pas, method TCustomTeePanel.NonBufferDraw, if I comment the following line, the exception appears later.
TTeeCanvas3DAccess(InternalCanvas).IKeepBitmap:=False; [created:2011-05-19T13:26:34.000+01:00 reported by:yeray@steema.com reported in version:2011.03.30407 (TeeChart VCL)]
Comment 1 david berneda 2013-12-04 05:18:23 EST
Cannot reproduce. The problem should be fixed with latest code.
Tested with both GDI and GDI+, using FastMM with define "FullDebugMode".
Memory, handles and GDI user objects are stable, they dont grow up to a crash.
Tests done up to 10000 bitmap creations.
