Bug 314 - [TV52015608] Having a line with some thousand points and XValues.Order=loNone, if ...
Summary: [TV52015608] Having a line with some thousand points and XValues.Order=loNone...
Reported: 2011-06-10 16:48 EDT by yeray alonso
Modified: 2013-12-04 04:59 EST (History)
Description yeray alonso 2013-11-20 10:37:59 EST
Having a line with some thousand points and XValues.Order=loNone, if you zoom several times, a vertical line is drawn over the chart.
Code to reproduce it:
uses Series;
  Chart1.AddSeries(TLineSeries).FillSampleValues(10000);
  Chart1[0].XValues.Order:=loNone;
  Chart1.Axes.Bottom.SetMinMax(1000,1025);
Forums topic:
http://www.teechart.net/support/viewtopic.php?f=3&t=12385&p=53400#p53400 [created:2011-06-10T15:48:40.000+01:00 reported by:yeray@steema.com reported in version:2011.03.30407 (TeeChart VCL)]
Comment 1 david berneda 2013-12-04 04:59:21 EST
The internal Line/Area/HorizLine series calculation to avoid pixel coordinates overflow maximum coordinates (Series.pas CalcPosLeftRight etc) has been improved and corrected.
A new check is done for every line segment to avoid painting it, if the line origin or ending XY coordinates are not inside (or do not cross) the Chart bounds rectangle.
Also fixed the above checking methods for horizontal series (HorizLine, etc)
