Bug 312 - [TV52015650] Some change from v8.08 to v2010.01 has affected the custom drawing. ...
Summary: [TV52015650] Some change from v8.08 to v2010.01 has affected the custom drawi...
Reported: 2011-07-08 13:56 EDT by yeray alonso
Modified: 2015-04-16 05:33 EDT (History)
test project (1.32 KB, application/zip)
2015-04-16 05:30 EDT, yeray alonso
Description yeray alonso 2013-11-20 10:37:53 EST
Some change from v8.08 to v2010.00 has affected the custom drawing.
In the attached application, if you click the button, some lines are drawn. Then, if you drag the window partially out of the screen and then back to the middle, the part of the chart that was out of the screen is now clean.
But then, if you click the button again, in v8.08 more lines are drawn while not in v2010.00
Tests made with RAD 2010 as v8 is not supported with XE. [created:2011-07-08T12:56:04.000+01:00 reported by:yeray@steema.com reported in version:2010.00.00407 (TeeChart VCL)]
Comment 1 yeray alonso 2015-04-16 05:30:19 EDT
Created attachment 428 [details]
test project
Reproduced with the attached project in Delphi 7 and TeeChart v2010.01
Comment 2 yeray alonso 2015-04-16 05:33:16 EDT
Works fine since TeeChart v2011.04.
