Bug 305 - [TV52015700] The Clicked method doesn't seem to work fine with Bar series and 3D: ...
Summary: [TV52015700] The Clicked method doesn't seem to work fine with Bar series and...
Reported: 2011-08-17 12:44 EDT by yeray alonso
Modified: 2014-03-19 14:01 EDT (History)
Project with non-orthogonal 3D chart showing the problem. (57.62 KB, application/x-zip-compressed)
2014-03-14 08:34 EDT, narcís calvet
Description yeray alonso 2013-11-20 10:37:30 EST
It worked a litle bit better in v6 (see the attachments)
Probably related to TV52014246.
It happens in .NET too.
var i, j: Integer;
    s: TBarSeries;
    Chart1.Align:=alClient;
    Chart1.View3DOptions.Orthogonal:=false;
    Chart1.DepthAxis.Automatic:=false;
    Chart1.DepthAxis.Maximum:=8;
    Chart1.DepthAxis.Minimum:=-0.5 ;
    Chart1.DepthAxis.Visible:=true;
    Chart1.DepthAxis.Increment:=100;
    Chart1.View3DOptions.Rotation:=350;
    Chart1.View3DOptions.Elevation:=355;
    Chart1.View3DOptions.Zoom:=85;
    for i:=1 to 9 do
        s:=TBarSeries.Create(Chart1);
        s.ParentChart:=Chart1;
        s.Title:='Y' + IntToStr(i-1);
        s.MultiBar:=mbNone;
        s.ZOrder:=(i * 4) - 1;
        for j:=0 to 3 do
          s.Add(1000-i*80);
procedure TForm1.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
  Shift: TShiftState; X, Y: Integer);
var SeriesIndex, ValueIndex: Integer;
  for SeriesIndex:=0 to Chart1.SeriesCount-1 do
    ValueIndex:=Chart1[SeriesIndex].Clicked(X,Y);
    if ValueIndex>-1 then
      Break;
    Chart1.Title.Text.Text:='Series: '+IntToStr(SeriesIndex)+', ValueIndex: '+IntToStr(ValueIndex)
    Chart1.Title.Text.Text:='Background';
end; [created:2011-08-17T11:44:02.000+01:00 reported by:yeray@steema.com reported in version:2011.03.30407 (TeeChart VCL)]
Comment 1 narcís calvet 2014-03-14 08:34:40 EDT
Created attachment 116 [details]
Comment 2 david berneda 2014-03-19 13:31:49 EDT
Yes. 3D is not being considered.
There is no "ClickedCube" function yet that can be used by Bar series in 3D.
Comment 3 david berneda 2014-03-19 14:01:56 EDT
Implemented TCustomBarSeries.PointInCube valid for both Bar and HorizBar series.
The fix should also work fine in 3D Orthogonal mode.
Also added new TCanvas3D.CubeHull function that returns the polygon boundaries for a given rectangle and Z0,Z1.
In the attached example, this code will show the correct Series and ValueIndex:
var tmp : String;
  tmp:=GetEnumName(TypeInfo(TChartClickedPartStyle), Integer(Part.Part));
  if Assigned(Part.ASeries) then
     tmp:=tmp+' '+SeriesTitleOrName(Part.ASeries)+' '+IntToStr(Part.PointIndex);
  Memo1.Lines.Add(tmp);
