Bug 271 - [TV52016026] Use a Custom Palette for the TContourSeries. If we try the code belo...
Summary: [TV52016026] Use a Custom Palette for the TContourSeries. If we try the code ...
Reported: 2012-02-09 17:36 EST by yeray alonso
Modified: 2013-12-19 11:35 EST (History)
Description yeray alonso 2013-11-20 10:35:40 EST
If we try the code below, the default palette is still used:
uses TeeSurfa;
var JMPPalette: TCustom3DPalette;
    i: Integer;
  with Chart1.AddSeries(TContourSeries) as TContourSeries do
    FillSampleValues();
    SetLength(JMPPalette,5);
    JMPPalette[0].Color:= clBlack;
    JMPPalette[1].Color:= clBlue;
    JMPPalette[2].Color:= clGreen;
    JMPPalette[3].Color:= clYellow;
    JMPPalette[4].Color:= clRed;
    NumLevels:=Length(JMPPalette);
    CreateAutoLevels;
    for i := 0 to NumLevels-1 do JMPPalette[i].UpToValue:=Levels[i].UpToValue;
    Palette:=JMPPalette;
    Marks.Visible:=true;
    Brush.Style:=bsSolid;
I think the problem is that when we assing the custom Palette, the ILevels color list should use it.
Aproximation:
Changing the 3992 in TeeSurfa.pas, where says:
          tmpIso.Palette[t].Color:=ILevels[t].Color;
For this:
          tmpIso.Palette[t].Color:=Palette[t].Color;
The example above works fine but it breaks the colors when you don't use a palette.
Suggested fix!
In TeeSurfa.pas, in the PrepareLevels procedure. If you change the line:
        Color:=Level.InternalColor;
For this:
      if UsePalette then
        Color:=Palette[TheLevel].Color
Then you can add UsePalette:=true in your application to make the custom palette work. [created:2012-02-09T17:36:24.000+01:00 reported by:yeray@steema.com reported in version:2011.04.41118 (TeeChart VCL)]
Comment 1 david berneda 2013-12-19 11:22:31 EST
One easy way to make it work is to set the Color manually:
      Levels[i].Color:=JMPPalette[i].Color;   // <----------- HERE
Maybe the best fix would be to make this automatically whenever the Palette property is changed:
    Series1.Palette:=JMPPalette;   // <---- At this time
Another workaround to make this work, it to call again CreateAutoLevels after then palette has been changed:
    Series1.CreateAutoLevels;    // <--- Calling this, will use JMPPalette
Comment 2 david berneda 2013-12-19 11:35:38 EST
Finally found a reason.
This problem its not exactly a bug. The problem is Series1.ColorEachPoint is True and so, the level colors are obtained from the Chart1.ColorPalette instead of from Series1.Palette.
Adding this code before calling CreateAutoLevels makes it to work fine:
    Series1.ColorEachPoint:=False;
    Series1.UseColorRange:=False;
    Series1.UsePalette:=True;
    CreateAutoLevels;
