Bug 267 - [TV52016059] If you add the points with color to your TSurfaceSeries, the surface ...
Summary: [TV52016059] If you add the points with color to your TSurfaceSeries, the sur...
Reported: 2012-03-01 14:07 EST by yeray alonso
Description yeray alonso 2013-11-20 10:35:28 EST
If you add the points with color to your TSurfaceSeries, the surface is drawn correctly but not the legend.
If you set UseColorRange to false, then the legend shows the colors and values you set, but the surface has changed to one uniform color.
uses TeeSurfa;
var col: TColor;
    x, z, m, n: Integer;
    y, range: Double;
  m:=5;
  n:=5;
  range:=255 / (m * n);
  with Chart1.AddSeries(TSurfaceSeries) as TSurfaceSeries do
    for x:=1 to m do
      for z:=1 to n do
        y:=x*z;
        col:=RGB(Round(y*range), Round(y*range), 0);
        AddXYZ(x, y, z, '', col);
    //UseColorRange:=false;
end; [created:2012-03-01T14:07:58.000+01:00 reported by:yeray@steema.com reported in version:2011.04.41118 (TeeChart VCL)]
