Bug 2653 - Importing of functions does not set datasource
Summary: Importing of functions does not set datasource
URL: http://support.steema.com/viewtopic.p...
Reported: 2023-11-22 04:57 EST by Ruben Bermudez
Modified: 2024-03-08 09:48 EST (History)
SteemaTChart (8.24 KB, image/png)
2023-11-22 04:57 EST, Ruben Bermudez
Description Ruben Bermudez 2023-11-22 04:57:11 EST
Created attachment 1059 [details]
SteemaTChart
Visual Studio 2022
.NET Framework 4.8
Steema.TeeChart.net Version 4.2023.11.6
When importing a function, the data source is set to null, therefore no data is found. In the tchart version 4.2023.4.18 the importing of a function was working correctly as it was setting the data source to the correct series. Has this behavior changed? Also when importing the chart the legend does not come up correctly as seen by screenshot, it is aligned to the left. Once clicked inside thee chart area the legend moves to the bottom.
Comment 1 marc meumann 2024-03-08 09:48:24 EST
This has been tested with build 4.2024.3.6 in the following way at runtime:
Open Chart with Point Series, populated with data:
- add average function and set datasource to first series
- Export chart to template stream, with data.
- Import template stream to new Chart
The second chart reflects the content of the first chart correctly.
test code:
//  1) Save the template into a Stream...
System.IO.MemoryStream stream = new System.IO.MemoryStream();
try
	// save only Chart and Series formatting, NOT including data
	tChart1.Export.Template.Save(stream);
	// 2) Load the template into other Chart...
	stream.Position = 0;
	tChart2.Import.Template.Load(stream);
	// restore the chart alignment (in this example)
	this.tChart2.Dock = DockStyle.Fill;
	// repaint the Chart
	this.tChart2.Refresh();
finally
	// remove the stream, it's no longer necessary...
	stream.Close();
Changes were made to a January build of TeeChart that resoved this issue.
