Bug 2623 - Installation failed
Summary: Installation failed
Product: TeeGrid for Delphi
: --- critical
Assignee: david berneda
Reported: 2023-07-26 06:37 EDT by Sergey A. Guralnik
Modified: 2023-11-21 08:09 EST (History)
Description Sergey A. Guralnik 2023-07-26 06:37:12 EDT
Acquired TeeGrid today. I downloaded two versions of the installer: 1.12 Binary and 1.11 Source. None of them could be installed. The text of the log is as follows:
TeeGrid
Compilation started: 26.07.2023 13:10:46
Win32 v28 (Delphi 11 and C++Builder 11 Update 3)
TeeGrid
Embarcadero Delphi for Win32 compiler version 35.0
Copyright (c) 1983,2022 Embarcadero Technologies, Inc.
17766 lines, 0.08 seconds, 158768 bytes code, 332 bytes data.
VCLTeeGrid
9608 lines, 0.20 seconds, 124980 bytes code, 384 bytes data.
DclVCLTeeGrid
782 lines, 0.14 seconds, 19464 bytes code, 216 bytes data.
FMXTeeGrid
4529 lines, 0.17 seconds, 59372 bytes code, 284 bytes data.
DclFMXTeeGrid
633 lines, 0.23 seconds, 17756 bytes code, 220 bytes data.
TeeGrid Installation
  VERSION:  2021
Installing...
Win32 v28 (Delphi 11 and C++Builder 11 Update 3) OK. Time:  1s
Win64 v28 (Delphi 11 and C++Builder 11 Update 3)
TeeGrid
Embarcadero Delphi for Win64 compiler version 35.0
17766 lines, 0.16 seconds, 241676 bytes code, 19304 bytes data.
VCLTeeGrid
9608 lines, 0.27 seconds, 190924 bytes code, 12108 bytes data.
FMXTeeGrid
4529 lines, 0.22 seconds, 101004 bytes code, 6064 bytes data.
  VERSION:  2021
Installing...
Win64 v28 (Delphi 11 and C++Builder 11 Update 3) OK. Time:  1s
Mac OSX64 v28 (Delphi 11 and C++Builder 11 Update 3)
TeeGrid
Cannot recompile Delphi package: TeeGrid.dpk
Embarcadero Delphi for Mac OS X 64 bit compiler version 35.0
Linker command line: "C:\Program Files (x86)\Embarcadero\Studio\22.0\bin\ld.exe" -arch x86_64 -o C:\Work\Components\TG\Sources\..\Compiled\Delphi28.osx64\System\bplTeeGrid28.dylib -e __ZN7Teegrid14initializationEv -dead_strip -dead_strip_dylibs -mark_dead_strippable_dylib -exported_symbols_list C:\Work\Components\TG\Sources\..\Compiled\Delphi28.osx64\System\TeeGrid.exp -dylib -export_dynamic -S -x -macosx_version_min 10.9 -F \System\Library\Frameworks -F \System\Library\PrivateFrameworks -L "C:\Program Files (x86)\Embarcadero\Studio\22.0\Lib\osx64\Release" -L "C:\Program Files (x86)\Embarcadero\Studio\22.0\Redist\osx64" -L C:\Work\Components\TG\Sources\Temp -rpath $ORIGIN -install_name @rpath/bplTeeGrid28.dylib -filelist C:\Work\Components\TG\Sources\..\Compiled\Delphi28.osx64\System\TeeGrid.lnk
Error: E2597 ld: warning: directory not found for option '-L/usr/lib'
 ld: warning: directory not found for option '-F\System\Library\Frameworks'
 ld: warning: directory not found for option '-F\System\Library\PrivateFrameworks'
 ld: warning: directory not found for option '-F/System/Library/Frameworks/'
 ld: file not found: /usr/lib/libiconv.dylib
Fatal: F2588 Linker error code: 1 ($00000001)
EXCEPTION:
Compilation aborted.
Comment 1 david berneda 2023-11-21 08:09:23 EST
This is a Delphi requeriment that should be done before using the TeeGrid recompilation tool.
Mac and iOS platforms can only be compiled after the SDK files have been transferred from a Mac machine to the Delphi PC using PAServer.
Run first an empty Firemonkey application on the Mac/iPhone, this will force Delphi to obtain the sdk.
When the sdk is inplace, TeeGrid recompile tool will work for Mac and iOS.
