Bug 2522 - Mouse events within legend bounds ignored even when legend is not visible
Summary: Mouse events within legend bounds ignored even when legend is not visible
Version: 33.210915
Reported: 2022-04-20 12:50 EDT by kevin.persons
Modified: 2023-03-15 13:03 EDT (History)
Description kevin.persons 2022-04-20 12:50:40 EDT
The TCustomChartLegend.Clicked function does not consider whether the legend is visible when calculating its return value. As a result, when TCustomChart.MouseMove calls Legend.Clicked to determine a legend item hover status, the subsequent events that should be called by CheckMouseSeries do not fire in the case where the invisible legend occupies the same screen area as the hovered chart series. The fix I've applied to my copy of the source is to change the following line in TCustomChartLegend.Clicked from:
   if PointInRect(GetLegendBounds,P) then
to:
   if Visible and PointInRect(GetLegendBounds,P) then
That seems to work for me, but maybe there are side effects that I haven't considered. Thanks.
Comment 1 david berneda 2023-03-15 13:03:33 EDT
Thank you very much, this is now fixed according to your "if Visible..." solution.
That check was missing.
Comment 2 david berneda 2023-03-15 13:03:50 EDT
Don't think it comes with any undesired side effect.
