Bug 2514 - Template export sets more than one Axis to Automatic=false
Summary: Template export sets more than one Axis to Automatic=false
: --- minor
Reported: 2022-03-17 06:23 EDT by christopher ireland
Modified: 2022-03-17 08:01 EDT (History)
Description christopher ireland 2022-03-17 06:23:56 EDT
To reproduce the issue, use the following code:
      tChart1.Aspect.View3D = true;
      tChart1.Aspect.Zoom = 80;
      tChart1.Aspect.Chart3DPercent = 100;
      tChart1.Tools.Add(typeof(Rotate));
      var surface = new Surface(tChart1.Chart);
      int count = 20;
      for (int x = 0; x < count; x++)
        for (int z = 0; z < count; z++)
          double y = Math.Cos(x) + Math.Sin(z);
          surface.Add(x, y, z);
      tChart1.Axes.Left.Automatic = false;
      using (var stream = new MemoryStream())
        tChart1.Export.Template.IncludeData = true; //default setting
        tChart1.Export.Template.Save(stream);
        stream.Position = 0;
        tChart2.Import.Template.Load(stream);
        tChart2.Axes.Bottom.Automatic = true;
        tChart2.Axes.Depth.Automatic = true;
Here we can see that when we set Left.Automatic to false, Bottom.Automatic and Depth.Automatic are also set to false.
