Bug 2504 - tlh file Problem importing ActiveX control to VSNet VC++ projects
Summary: tlh file Problem importing ActiveX control to VSNet VC++ projects
Reported: 2022-01-25 03:11 EST by marc meumann
Modified: 2022-01-25 08:20 EST (History)
Description marc meumann 2022-01-25 03:11:50 EST
When importing TeeChart AX to VC++ projects in Visual Studio .NET, the IDE creates a tlh interface mapping file for all the elements of the TeeChart Type Library.
Under the IMapPolygon interface there are two members with these names:
- Points
- GetPoints
Unfortunately, when VSNet builds the tlh file it sets the "getter" for Points to GetPoints causing a clash and compile error.
Workaround:
1. Comment one of the two elements in the tlh file if not used (if not, rename it for use), save and copy the file to a permanent location in your project folder space.
eg.
  VARIANT_BOOL Value );
  //IPolygonSeriesPtr GetPoints ( );
2. Change the import line for teechart2021.ocx i n your project from:
#import "yourpath/TeeChart2021.ocx"
to
#include "yourpath/TeeChart2021.tlh"
In this way the tlh file will not be regenerated every time you build the project so will not overwrite your change.
We are working on a permanent fix for this issue.
Comment 1 pep jorge 2022-01-25 08:20:44 EST
Breaking change, due to a conflict once the Visual Studio autoclass generator for VC++NET projects is done we've needed to change the following method name :
GetPoints() from IMapPolygon interface
to
GetPîxelPoints().
Available for the next TeeChart for ActiveX v2022 version.
