Bug 2485 - TeeGrid 1.11 FMX - always crashes on an empty grid with only column headers row defined, and no data attached.
Summary: TeeGrid 1.11 FMX - always crashes on an empty grid with only column headers r...
Product: TeeGrid for Delphi
Hardware: PC All
: Normal critical
Assignee: david berneda
Reported: 2021-11-21 23:08 EST by Vsevolod V Gromov
Modified: 2022-11-03 06:28 EDT (History)
Description Vsevolod V Gromov 2021-11-21 23:08:54 EST
Whenever an empty (data-less) grid control is being hovered over, it would try to FindRow (Tee.Grid.Rows.pas, line 1353)
This subroutine, is throwing AV at line 1378, because there is no Data assigned.
Work-around:
Adding the following at the routine start would fix that, also eliminating the reulst := -1; at the end of this sub.
Result := -1;
if not Assigned(Data) then
  exit;
Comment 1 marc meumann 2022-11-03 06:28:52 EDT
Thank you for the input Vsevolod. Modification included.
