Bug 2447 - Area series are drawn in the wrong order.
Summary: Area series are drawn in the wrong order.
Reported: 2021-07-09 12:31 EDT by Brian Kohrs
Modified: 2021-07-19 07:15 EDT (History)
Description Brian Kohrs 2021-07-09 12:31:22 EDT
If you have a 3D chart with multiple area series, they are drawn in the wrong order. It appears that the logic in Area.DrawSeriesAscending is the issue. If I descend from Area and "fix" the logic, it draws it in the correct order. I have provided an example here: https://github.com/jhabkohrs/TeeChartAreaSeriesOrder.
Comment 1 Brian Kohrs 2021-07-12 11:52:48 EDT
(In reply to Brian Kohrs from comment #0)
After some additional testing, the same issue exists for HorizBar series. While there is a workaround for Area, the DrawSeriesAscending method is internal for HorizBar, so there is no workaround for HorizBar.
Comment 2 Brian Kohrs 2021-07-12 14:57:41 EDT
(In reply to Brian Kohrs from comment #1)
I withdraw my comment about HorizBar series. In trying to create a simple reproduction case, I found it was an issue with my data, not with the component.
