Bug 2441 - TFont in Tee.Format.pas does not handle negative Size
Summary: TFont in Tee.Format.pas does not handle negative Size
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2021-06-28 23:13 EDT by dean.mustakinov
Modified: 2021-09-15 07:05 EDT (History)
Description dean.mustakinov 2021-06-28 23:13:38 EDT
VCL TFont uses negative Size to specify that internal leading on top of each line of text is included in Size.
TeeGrid assigns Self.Font.Size to Tee.Format.TFont.DefaultSize when ParentFont = true.
If parent uses negative Size then Tee.Format.TFont does not work correctly.
I have made a simple workaround for this in Tee.Format.pas:
-added public function to convert between negative and positive Size
class function TFont.GetTeeFontSize(const AWinFontSize: Single): Single; // DM CHANGE
  if AWinFontSize >= 0 then result := AWinFontSize
  else result := Abs(AWinFontSize) * 0.9; // approximately font size - internal leading
-changed following methods to use the GetTeeFontSize when setting internal font size:
Constructor TFont.Create(const AChanged: TNotifyEvent);
  inherited;
  FName:=DefaultName;
  DefaultStyle:=[];
  FBrush:=TBrush.Create(AChanged);
  FBrush.InitColor(TColors.Black);
  FSize:=GetTeeFontSize(DefaultSize); // DM CHANGE
procedure TFont.Assign(Source: TPersistent);
  if Source is TFont then
    Brush:=TFont(Source).FBrush;
    FName:=TFont(Source).Name;
    FSize:=GetTeeFontSize(TFont(Source).FSize); // DM CHANGE
    FStyle:=TFont(Source).FStyle;
  end
    inherited;
function TFont.IsSizeStored: Boolean;
  result:=GetTeeFontSize(FSize)<>GetTeeFontSize(DefaultSize); // DM CHANGE
procedure TFont.SetSize(const Value: Single);
  if FSize<>GetTeeFontSize(Value) then // DM CHANGE
    FSize:=GetTeeFontSize(Value); // DM CHANGE
    Changed;
Comment 1 marc meumann 2021-09-15 07:05:55 EDT
Thank you Dean. Code included.
