Bug 244 - [TV52016272] Having a TLineSeries (doesn't happen with a TFastLineSeries), if you ...
Summary: [TV52016272] Having a TLineSeries (doesn't happen with a TFastLineSeries), if...
Reported: 2012-07-23 13:34 EDT by yeray alonso
Modified: 2013-11-20 10:34 EST (History)
Description yeray alonso 2013-11-20 10:34:17 EST
Having a TLineSeries (doesn't happen with a TFastLineSeries), if you set a significant marks arrow, some extra space in the left axis is taken to fot the marks. However, no new axis labels are drawn in the new space.
This worked fine in v2012.05 but in v2012.06. See the images attached
uses Series, TeeConst;
  Chart1.Title.Text.Text:=TeeMsg_Version;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TLineSeries) do
    Add(0);
    Add(1000);
    Marks.ArrowLength:=35;
    Marks.Visible:=true;
Probably the same:
Having a TLineSeries (doesn't happen with a TFastLineSeries) if you use the MaximumRound property si the Internal Maximum (IMaximum at TChartAxis.CalcRoundScales in TeEngine.pas) is modified, the new label isn't drawn.
    Add(0);
    Add(945);
  Chart1.LeftAxis.MaximumRound:=true;
http://www.teechart.net/support/viewtopic.php?f=3&t=13433&p=58757#p58757
 [created:2012-07-23T12:34:42.000+01:00 reported by:yeray@steema.com reported in version:2012.06.120613 (TeeChart VCL)]
