Bug 2438 - Change Percent width calculation to use remainder of the total width instead of full width
Summary: Change Percent width calculation to use remainder of the total width instead ...
Status: UNCONFIRMED
Product: TeeGrid for Delphi
Assignee: david berneda
Reported: 2021-06-25 00:11 EDT by dean.mustakinov
Modified: 2021-06-25 00:11 EDT (History)
Description dean.mustakinov 2021-06-25 00:11:28 EDT
When grid calculates the width of the column that is using the Percent then it calculates the width as percent of total available width.
If there are fixed or auto calculated width columns mixed with Percent width columns this can cause total width to be greater than max width of the grid.
Percent calculation should happen on the remainder of total width after all of the fixed and auto width columns have been calculated.
This is going to useful when there are one or two percent columns that should take up the remainder of available width.
I have made this change in Tee.Grid.RowGroup.pas (my changes are commented with // DM CHANGE):
procedure TRowGroup.CheckColumnsWidth(const APainter:TPainter; const Forced:Boolean;
                                      const AWidth:Single);
  // Collection of columns
  function Check(const AColumns:TColumns):Single;
  var TotWidth: Single; // DM CHANGE
    // Single column
    procedure Calculate(const AColumn:TColumn);
      if AColumn.Width.Automatic then
        if AColumn.HasItems then
          TColumnWidthAccess(AColumn.Width).IPixels:=Check(AColumn.Items); // <-- recursive
          AColumn.ValidWidth:=True;
        end
        if Forced or (not AColumn.ValidWidth) then
           DoCalcWidth(APainter,AColumn,TotWidth); // DM CHANGE
      end
      if AColumn.Width.Units=TSizeUnits.Percent then
  var t : Integer;
      tmp : TColumn;
    result:=0;
    // DM CHANGE START
    TotWidth := AWidth;
    for t:=0 to AColumns.Count-1 do
      tmp:=AColumns[t];
      if tmp.Visible and (tmp.Width.Units=TSizeUnits.Pixels) then // DM CHANGE
        Calculate(tmp);
        result:=result+tmp.Width.Pixels;
    // // DM CHANGE - calc percent width on remainder
    TotWidth := AWidth - result;
      tmp:=AColumns[t];
      if tmp.Visible and (tmp.Width.Units=TSizeUnits.Percent) then
        Calculate(tmp);
    // DM CHANGE END
  Check(Columns);
  Columns.ValidWidth:=True;
