Bug 243 - [TV52016283] There is a customer who would like to export the series data to a csv...
Summary: [TV52016283] There is a customer who would like to export the series data to ...
Reported: 2012-07-31 12:15 EDT by yeray alonso
Modified: 2013-12-03 09:28 EST (History)
Description yeray alonso 2013-11-20 10:34:13 EST
There is a customer who would like to export the series data to a csv, but only for the active series.
I see 2 Options (second more flexible):
Option1: We could add a new boolean (ie AllSeries) to set if all the series should be considered or only the active (all by default, to preserve backwards compatibility).
In TeeStore.pas, in the TSeriesDataText.PointToString function the following code is executed:
  if Assigned(Series) then
     DoSeries(Series)
  for t:=0 to Chart.SeriesCount-1 do
      DoSeries(Chart[t]);
We could modify it for the following:
     DoSeries(Series)
      if AllSeries or Chart[t].Active then DoSeries(Chart[t]);
There is at least another place where we should add this extra verification.
The Header function is a nested function into TSeriesDataText.AsString function (still in TeeStore.pas). At the end, it says:
       result:=result+HeaderSeries(Series)
    if Chart.SeriesCount>0 then
      result:=result+HeaderSeries(Chart[0]);
      for t:=1 to Chart.SeriesCount-1 do
          result:=result+TextDelimiter+HeaderSeries(Chart[t]);
So we should modify it to also add the header only when needed:
      if AllSeries or Chart[0].Active then result:=result+HeaderSeries(Chart[0])+TextDelimiter;
          if AllSeries or Chart[t].Active then result:=result+HeaderSeries(Chart[t])+TextDelimiter;
Option2: Alternativelly, we could make the Series property in TSeriesDataText to accept an array of series. This would allow the user to export only the desired series. This would be more flexible.
http://www.teechart.net/support/viewtopic.php?f=3&t=13447&p=58855#p58855 [created:2012-07-31T11:15:50.000+01:00 reported by:yeray@steema.com reported in version:2012.06.120613 (TeeChart VCL)]
Comment 1 david berneda 2013-12-03 09:28:09 EST
This wish has been implemented, at the base class TSeriesData (TeeStore.pas unit), so all derived export format classes now have a new property (an array of Series) to filter which Series should be exported.
This applies to TSeriesDataText (txt, csv), TSeriesDataXML (xml), TSeriesDataHTML (html <table>), TSeriesDataXLS (Excel) and TSeriesDataJSON (json).
Usage example:
uses TeeStore;
var data : TSeriesDataText;
  data:=TSeriesDataText.Create(Chart1);
  data.IncludeHeader:=True;
  data.SeriesList.Clear;
  // Add only the Series you want to export:
  data.SeriesList.Add(Series3);
  data.SeriesList.Add(Series5);
  data.SeriesList.Add(Series6);
  Memo1.Text:=data.AsString;
  data.Free;
