Bug 2424 - Painting is 15 times slower with this option enabled
Summary: Painting is 15 times slower with this option enabled
Version: 17.160426
Reported: 2021-05-13 03:13 EDT by alex
Modified: 2021-05-13 05:22 EDT (History)
painting time ms x10 (115.96 KB, image/png)
2021-05-13 03:13 EDT, alex
Description alex 2021-05-13 03:13:27 EDT
Created attachment 962 [details]
Hi! Is there something special about SmallDots pen style? Cause it makes TChart 15 times slower.
These are the requirements:
Axis.Grid.SmallDots must be enabled.
The renderer must be GDI+
The anti-aliasing must be enabled, that's important.
Also:
Delphi 10.4, 32 bit Windows compiler.
TChart 17.160129 (the default included)
Windows 7.
And the code:
procedure TForm1.Button_test_Click(Sender: TObject);
 chart1.Series[0].FillSampleValues(10);  // TPointSeries
 t:=gettickcount;
 for var i:= 1 to 10 do chart1.Repaint;
 caption:=(GetTickCount - t).ToString;
procedure TForm1.Button_MakeItSlow_Click(Sender: TObject);
 chart1.LeftAxis.Grid.SmallDots:=true;
 chart1.BottomAxis.Grid.SmallDots:=true;
Make TChart big enough to see the slowdown. In my case it's fullscreen and normally the painting process takes 10 ms. With SmallDots it's 150 ms.
Comment 1 yeray alonso 2021-05-13 03:58:06 EDT
Non solid lines are very slow in GDI+ (and also GDI) compared to solid lines.
We recommend using TFastLineSeries for intensive drawing, which includes features to improve the drawing performance.
- DrawStyle property set to flAll
  Series1.DrawStyle := flAll;
  Series1.Pen.Style:=psSolid;
- You might also try disabling AntiAlias. This can be done in two ways:
1) At Chart level:
  (Chart1.Canvas as TGDIPlusCanvas).AntiAlias:=False;
2) At FastLine series level:
  Series1.FastPen := True;
- You can also use DrawAllPointsStyle daMinMax:
  Series1.DrawAllPoints:=false;
  Series1.DrawAllPointsStyle:=daMinMax
Comment 2 alex 2021-05-13 05:20:12 EDT
Good to hear you're aware. By the way, is there a TFastPoint series? Like FastLine, but with points?
Comment 3 yeray alonso 2021-05-13 05:22:10 EDT
No, I'm afraid there's no TFastPointSeries:
http://bugs.steema.com/show_bug.cgi?id=1746
