Bug 2398 - TCircularGauge does not draw the last point on the axis
Summary: TCircularGauge does not draw the last point on the axis
Version: 27.190530
: Highest critical
Assignee: yeray alonso
Reported: 2021-01-15 13:54 EST by alexandre
Modified: 2021-01-20 08:59 EST (History)
Attachments shown in the description (87.86 KB, application/x-zip-compressed)
2021-01-15 13:54 EST, alexandre
Description alexandre 2021-01-15 13:54:16 EST
Created attachment 954 [details]
There is a problem with the VCLTee.TeeCircularGauge.TCircularGauge.DrawAxis method that, in some circumstances, causes the last point on the axis not to be drawn. This is due to the fact that most of the local variables are of type Single while the properties of the components are Double.
Attached is a DFM of a form containing only one TChart component with a TCircularGauge series simply configured to illustrate the problem.
To make the source of the problem even clearer, the attached image shows the most relevant settings.
Also attached is an image showing the problem.
procedure TCircularGauge.DrawAxis;
// Axis.Increment: Double = 2402.4325
// tmpStep: Single = 2402.4326171875
tmpStep := Axis.Increment;
Comment 1 yeray alonso 2021-01-18 08:14:24 EST
Declaring tmpValue, tmpStep and tmpStep2 as TAxisValue in TCircularGauge.DrawAxis method fixes the problem.
Comment 2 alexandre 2021-01-18 12:06:01 EST
(In reply to yeray alonso from comment #1)
Hi Alonso,
In which version will this fix be available?
Thank you.
Comment 3 yeray alonso 2021-01-19 02:17:09 EST
This fix will be included in the next maintenance release (probably v2020.32).
I can't say when it will be published but if you want to tell me what IDE are you using I can prepare a beta version for you.
Comment 4 alexandre 2021-01-20 07:47:12 EST
(In reply to yeray alonso from comment #3)
> v2020.32).
Hi Alonso,
Can you send a patch (maybe .dcu or .pas) or just the source code of the method so I can create a new class, inherit and override the method?
My version of Delphi: 10.3.1.
My version of Steema: TeeChart Pro v2019.27.190530.
Thank you.
Comment 5 yeray alonso 2021-01-20 08:59:40 EST
(In reply to alexandre from comment #4)
I've just sent it to your mail.
