Bug 2309 - CopyToClipboardMetafile on system with Textscale > 100%
Summary: CopyToClipboardMetafile on system with Textscale > 100%
Version: 29.200113
: --- critical
Reported: 2020-04-04 13:08 EDT by henry.ernst@snafu.de
Modified: 2020-06-03 03:25 EDT (History)
Delphi / C++ Builder RAD IDE Version: RAD 10.2 Tokyo
Demo-Project for Reproduce (85.28 KB, application/x-zip-compressed)
2020-06-02 11:55 EDT, henry.ernst@snafu.de
Description henry.ernst@snafu.de 2020-04-04 13:08:38 EDT
Dear Teechart-Team,
i use Delphi 10.2.3, Teechart Pro 2019.27.190530 VCL and Windows 10.0.18363.
The users of my software can copy a Chart to Clipboard.
To do this with "Chart1.CopyToClipboardMetafile(true);".
But on Devices with Textscaling more than 100% (i.e. Surfacebook 2 with 200%) there is an issue.
After pasting the graphic in Word or Powerpoint there is an frame for the hole graphic. But the content of the chart take only a part (i.e. quarter) from the frame.
You ca reproduce the problem with the attached sample.
Is ther any workaround or bugfix for this problem?
Thanks and regards Henry
Comment 1 henry.ernst@snafu.de 2020-06-02 11:55:50 EDT
Created attachment 939 [details]
Comment 2 marc meumann 2020-06-02 12:18:58 EDT
Hello Henry,
We can offer you alternative code to achieve the CopyToClipboard.
Excerpt taken from this forum thread:
https://www.steema.com/support/viewtopic.php?f=3&t=15936#p70743
Code:
var tmpRect: TRect;
    tmpWidth, tmpHeight: Integer;
  tmpRect:=Chart1.GetRectangle;
  tmpWidth:=tmpRect.Right-tmpRect.Left;
  tmpHeight:=tmpRect.Bottom-tmpRect.Top;
  tmpRect.Right:=tmpRect.Right+tmpWidth;
  tmpRect.Bottom:=tmpRect.Bottom+tmpHeight;
  Chart1.CopyToClipboardBitmap(tmpRect);
Comment 3 yeray alonso 2020-06-03 03:25:47 EDT
You may want to "Enable High-DPI" in your project options, concretely under "Application".
In Rio and Sydney, more options where added and the preferred way to go is by using "Per Monitor v2" "DPI Awareness" under "Application/Manifest".
Setting this option, the given project seems to work fine without any extra code.
