Bug 2303 - The TeeGrid 1.09 cannot be installed in Lazaurus 2.06
Summary: The TeeGrid 1.09 cannot be installed in Lazaurus 2.06
Product: TeeGrid for Delphi
: --- blocker
Assignee: david berneda
Reported: 2020-03-24 08:25 EDT by Jakub Cebula
Modified: 2020-03-31 03:31 EDT (History)
Log from TeeGridRecompile (4.11 KB, text/plain)
2020-03-24 08:25 EDT, Jakub Cebula
Description Jakub Cebula 2020-03-24 08:25:35 EDT
Created attachment 935 [details]
My attempts to install TeeGrid 1.09 on Lazaurus 2.06 failed. Failed to compile sources. The compiler terminates compilation. Version 1.08 TeeGrid installs without any problem in the same Lazaurs configuration.
I attach the log from version 1.09 TeeGrid.
Lazaurus is installed in the C:\Lazaurus directory, and TeeGrid itself in C:\Lazaurus\TeeGrid. Windows 10 x64 version 10.0.18363.720
Colud you check it?
Thankyou in advance
JC
Comment 1 yeray alonso 2020-03-31 03:31:45 EDT
We've recently fixed this error while compiling for Lazarus.
Modify the TFilterComboBox.FilterItems method in the "Sources\VCL\VCLTee.Control.pas" unit for the following and try to recompile.
procedure TFilterComboBox.FilterItems;
var
  I: Integer;
{$IFNDEF FPC}
  Selection: TSelection;
{$ENDIF}
{$IFNDEF FPC}
  // store the current combo edit selection
  SendMessage(Handle, CB_GETEDITSEL, WPARAM(@Selection.StartPos),
    LPARAM(@Selection.EndPos));
{$ENDIF}
  //start filter cycle
  Items.BeginUpdate;
  try
    // if the combo edit is not empty, then clear the items
    // and search through the FStoredItems
    if Text <> '' then
      // clear all items
      Items.Clear;
      for I := 0 to FStoredItems.Count - 1 do
        if AnsiContainsText(FStoredItems[I], Text) then
          Items.Add(FStoredItems[I]); //resulting matched items
    end
      // if no match, ie. empty filter, add all items.
      Items.Assign(FStoredItems)
  finally
    Items.EndUpdate;
{$IFNDEF FPC}
  // restore the last combo edit selection
  SendMessage(Handle, CB_SETEDITSEL, 0, MakeLParam(Selection.StartPos,
    Selection.EndPos));
{$ENDIF}
