Bug 2279 - Can not trigger an event When clicking a button
Summary: Can not trigger an event When clicking a button
Status: RESOLVED WONTFIX
Reported: 2020-01-20 03:00 EST by liujia
Modified: 2020-03-30 04:39 EDT (History)
screenshot (148.84 KB, application/x-rar)
2020-01-20 03:00 EST, liujia
Description liujia 2020-01-20 03:00:29 EST
Created attachment 927 [details]
screenshot
Steps:
1.I use the Tchart to draw a 3D figure. Then I add some points3Ds,and I set the "Tools"->"Other"->"Rotate".
2.I set the tchart event called "tchart1.ClickSeries".
My problem:
I can click the points3D to trigger "tchart1.ClickSeries" event When the tchart is loading completed.
But I can not trigger this event when I click or drag the tchart to rotate.
Comment 1 liujia 2020-01-20 03:01:45 EST
But I can not trigger this event after I click or drag the tchart to rotate.
Comment 2 christopher ireland 2020-01-20 08:35:58 EST
Hello!
This is expected behavior - there's a thread on the support forums in which the same happens in a similar set of circumstances:
http://support.steema.com/viewtopic.php?f=3&t=6821
Unfortunately we have no plans to attempt to get this to work.
Comment 3 christopher ireland 2020-01-20 08:41:15 EST
By adding a Rotate tool to a Chart and rotating it, the Chart is automatically displayed in:
Orthogonal=false
If you set this to true, i.e.
_tChart.Aspect.Orthogonal = true;
You will see the difference and will also be able to get the ClickedSeries event working again.
Comment 4 liujia 2020-01-20 20:40:18 EST
Thank you!
I have another question about the 3D  figure.
I want to show the "Z" Mark Tips when the mouse over the points.But I can not find
any set configs.The Mark Tips panel has only "Value","Percent","Label"..."X and Y"
Comment 5 liujia 2020-01-20 21:02:16 EST
I want to display some custom information on marktip,what should I do?
Comment 6 liujia 2020-01-20 21:34:18 EST
I have solved my problem of comment 5
Comment 7 christopher ireland 2020-01-21 07:08:38 EST
with respect to your comment 4:
You can use code similar to the following:
        TChart _tChart;
        Points3D _points3D;
        MarksTip _marksTip;
            _tChart = new TChart();
            _tChart.Dock = DockStyle.Fill;
            splitContainer1.Panel2.Controls.Add(_tChart);
            _points3D = new Points3D(_tChart.Chart);
            _points3D.FillSampleValues();
            _tChart.Aspect.View3D = true;
            _tChart.Aspect.Chart3DPercent = 50;
            _marksTip = new MarksTip(_tChart.Chart)
                Series = _points3D,
                Style = MarksStyles.XValue
            _marksTip.GetText += _marksTip_GetText;
        private void _marksTip_GetText(MarksTip sender, MarksTipGetTextEventArgs e)
            var idx = _points3D.XValues.Value.Select(x => x.ToString(_points3D.ValueFormat)).ToList().IndexOf(e.Text);
            var yval = _points3D.YValues[idx].ToString(_points3D.ValueFormat);
            var zval = _points3D.ZValues[idx].ToString(_points3D.ValueFormat);
            e.Text += $" {yval} {zval}";
